35152 is the Executive Protection Unit talkgroup, and 35799 would be the status bit +7 for 35792 5-COMM Dispatch South, which indicates a Multi-Select by the dispatcher. Basically, it means the dispatcher was (probably) intentionally transmitting on both talkgroups at the same time. That being said, you should've seen 35152 and 35792 if your Status Bits is set to Off/Ignore, you should've only seen 35799 if you had Status Bits On.
