NM State Police
rk911
Rich
Wheaton, IL
can anyone tell me if the NMSP are still on VHF? we're on vacation and have been in Las Cruces and now Ruidoso and i've yet to hear anything on any of the frequencies in the RR database. have the SP ops moved to a different mode??
73
rich, n9dko
Fowler
FL
They use satellite coms for their CADS. Might be using that more than voice. They also use duplex. Base is on one freq, mobiles are on another.
Fowler
rk911
Rich
Wheaton, IL
hmmmm. i'm using a HH receiver in the camper so i know it's not the greatest but when we were in arizona earlier this month i was able to hear the AZSP on their freqs. just fine...and from quite a distance. not sure which dist. ruidoso is in but according to my info there are dist. hq's in las cruces and roswell...roswell is closer but not hearing a peep.
i did see what looked like a small sat. dish on the roof of the one NMSP sqaud we saw a couple of days ago. i've never seen that kind of setup before. if their voice coms are also via sat. that sure would explain why i'm not hearing anything.
thanks for the info.
73
rich, n9dko
They mainly use the sat comm for silent runs, or sensitive info over the air. such as social security numbers, details on calls requiring secure comm, accidents pertaining to ones privacy or anything needing to be secured. how ever main traffic is used on the duplex primary of 155.7900 as the dispatch out and units in on 155.7300 if you have a modern digital/analog authorized 2way this can be setup to monitor it and you will have clear solid traffic conversations for nmsp ch 1. allot of units use 155.5500 (state car) or some dispatch areas use this around roswell to ruidoso etc. motor transportation (DOT) uses nmsp channels now along with the sat comm and youll hear for example "Alamogordo Mary 194" Alamogordo (or whichever city is calling place there) meaning the dispatch office calling, The DOT silver cars Motor unit M-ary and the officers car number. I know they still use there old setup in DOT units using there 4 unit plate number, but when on nmsp which they mainly use they use a 3 digit number, idk why or what the full setup is. Also the satellite is used for laptops, which most of the dispatch calls out are sent to the computer then it beeps notifying the unit being sent and the officer can read the screen, or use the audio aloud feature where it reads what the dispatch has sent to keep eyes on road while driving. a click of the ack key sends notification to the nmsp dispatcher telling them 10-4 enroute or theyll use the vhf and say there enroute.
I know the units use a repeater system within the trunk for the officers portable and mobile. Now what freq relays it to the officer Idk. It seems they keep it hush or wont say. But I know they had a NMSP officer here and he couldnt get out on his portable on NMSP ch1 with his unit too far away. so he went to state car and got ahold of dispatch that way.
I know the newer XTS and XTL portables monitor the duplex of them without any issue other then just simple programming. But the ht series theyd use the repeater access function with the code for it in programming. As far as I know only the NMSP communications knew it and wouldnt even tell local police depts. We always have just used state car to access there dispatch or units. But a new XTS digi capable mobile we got can access the nmsp ch 1 primary and the comm guy here said it is easier then the old radios and dont need anything extra done other then programming the freq in. auto detecting i guess.
If you use a hand held 2 way (for ham users or vol fire) a good moto or kenwood antenna at least a 8 to 9inch thats out will pick up mostly. If you got a mobile radio a good antenna mounted onthe trunk or roof you should hear them no problem. But they do still use the vhf system allot because i have it programmed into my HT and can hear them on scan with scanning the in and out channel. im not sure how to change it for the duplex (any help anybody) as it was a old dept radio given to use for home and has input on ch 16 and out on 15 on the portable.
Idk if this helps any.
theyll always use the vhf or uhf setups because most new mexico cities plan to stay on vhf. allot of state units cross into other districts in a shift or assigned week by week to fill in. so it is necessary they use the old system too or have it. plus the sat comm is the unit only linked to the laptop terminal. the portables use the vhf system on a odd ball setup. but also vhf im told is a back up for or if the sat com or computers go down.
i know there using a repeater duplex system on the primary 2 channels. then each unit has its own repeater in trunk. idk if its a special setup but can hear it on a 2way with a real good antenna. state car usually has activity or personal chatter. state len 155.475 i believe they also use now.
there is a new channel called Vlaw for new mexico interop. ill have to find it and post it from the office. from what i saw, there will be a Vlaw, Ulaw then which ever city needs will have a link simulcast to them if they use 800mhz or etc. idk if there for digital or analog. i know no one hardly uses them lately. just tests.
