NMO Hood Mount
IdleMonitor
The Ottawa Valley - Eastern Ontario
What's a good nmo hood mount for a '24 Trailblazer?
I'm not keen at this moment about drilling a hole for the roof, and for now I'm gonna stay away from the magnet mount even though I have that readily available. I have a great nmo antenna to use, just need a proper mount for the antenna.
My only other option is something simple to put an nmo mount on the side of the hood. What's some good options?
NMO's installed, while-u-wait.
Mounting off the fender will make the antenna directional away from the body. Also having it down below the roof line results in some shielding. Not ideal for good performance. Permanent NMO on the roof will outperform it. Mag mount on the roof will out perform it.
But if you are really reluctant to do the permanent mount, there are 90º NMO brackets that will do what you want.
IdleMonitor
IdleMonitor
I found the Laird trunk lip mount to be very high quality and strong and I use two on my Jeep hood. Others have used a Midland brand on the same vehicle and reported problems. The Laird comes in chrome or black and you can sometimes find them new on eBay for around $20. Here is a black one on my Jeep.
I just went and checked on my hood and there doesn't seem to be a good spot even for one of those types of mounts.
steve9570
Member WSAG-457 -KB1-KZW- KCP-2441 CB-WA1-BZG
Natick Ma
IdleMonitor
My only other compromise at this time seems to be one of the spectrum force wideband magnet mount antennas. It fits just perfect at the corner of the window/hood area and the coax is small enough to come through properly. I've used this before and surprisingly works quite well for the size.
My next question is, where can I get one? Amazon doesn't seem to have them right now and ScannerMaster costs way too much to ship them to Canada. The ones I do have seem to have a short somewhere in the coax near the base of the antenna.
The Bingfu ones on Amazon are only 12 inches in length, the SpectrumForce is 17 inches. I believe TRAM also makes one of these comparable to the SpectrumForce also, but can't find them either.
Mattydog
Sechelt, Birtish Colombia, Canada
There's Lip Mounts & Fender Mounts
