Firekite
- Joined
- Apr 2, 2019
- Messages
- 471
I’m about to put 3 holes in the roof of my 2011 F250 4-door. Time to abandon the mag mounts. My plan is to install 3x Larsen NMOKHFUD (NMO w/RG-58U dual shield), one as close to dead center as possible for ham VHF/UHF which will be Larsen NMO2/70B or NMO2/70SH as I have both, one for CB (and likely 10m experimentation) which will be Larsen NMO27BS and may get swapped around for 6m or other setups in the future, and one for scanner use which will be Larsen NMO150/450/758. The FTM-400 will go under the driver’s seat. CB and scanner will be center of the dash. When not in use (and when going through a tunnel wash or garage parked) each of the mounts will be capped with a Laird QWRCB.
I have no sunroof to worry about, the full roof to use. However, the roof isn’t flat. It has substantial raised ribbing but also is slightly crowned so that the center is higher than the edges (door openings). I know all mobile installations are compromises, but here’s an illustration:
![95A2A94B-6E6D-49BF-9FD7-E0A518A1F7D6.jpeg 95A2A94B-6E6D-49BF-9FD7-E0A518A1F7D6.jpeg](http://forums.radioreference.com/data/attachments/83/83053-31488300215bc8d863d3ce4b125033b3.jpg)
My initial thought is that since from dead center I have a radius of at least 20” to the nearest edges, and it’s the VHF/UHF transceiver is the only one that actually gets used with any consistency, it gets pride of place. I figure the other two I can put in each rear corner as far away as is reasonably achievable. Those are the yellow dots.
However, that would definitely result in that 50” antenna sticking up at a drunken angle since the crown of the roof gets more pronounced toward the edges. As a result I thought maybe it would be better to put at least one of the mounts on the center line at the back near the 3rd brake light, which is the green dot. And maybe even move the other somewhere near the front instead, maybe for scanner use, where it can be a little flatter and kinda sorta farther from the center, which is the blue dot. Looking cool isn’t the priority.
I’ve never approached an install like this, though, and I could really use any suggestions born from understanding and hard-won experience. I’m tempted to eliminate the 3rd mount entirely and just throw a good magnet mount on there for those rare times (mostly road trips) that I actually use the scanner, which I’ve done and works well. But I figure while I’m punching holes I might as well do it right and just cap it if I’m not using it, saving the magnet mount for truly temporary stuff.
Any help (with explanations ideally) would be appreciated!
