repairman222
When installing a Nmo trip lip antenna mount, do I need to sand the paint down to bare metal? Just using a multi band antenna to receive scanner freqs. No transmit. Thanks members.
I have the 2 alan screws just don't know if its grounded good, my receive is effy.There should be two set screws that dig into the lip of the trunk lid and that should make a good ground connection.
My reception is iffy, might need a ground strap.I don't think so, maybe it would help especially if you were transmitting, anytime I used a lip mount I've never done that but do be very careful of the molding, you don't want anything digging into the molding then causing a leak into your trunk.
Then again you could just drill a hole but I understand that's not possible in a lot of cases.
from the metal screw to the metal truck?You can easily confirm if you have ground connectivity via a simple multimeter in continuity mode.
You can check this with relative ease using an ohm meter or continuity tester.I have the 2 alan screws just don't know if its grounded good, my receive is effy.
With the screws in the trunk lip mount? Hammer time?Those small hex screws have a rounded pointed tip that really grinds through the pain into the bare metal by design. They are made to create a good ground. Before tightening the screws I usually give the lip mount a little tap with a hammer just to make sure it's on as tight as possible and flush against the lip of the trunk.
