[No. 698] All protocol is \"No Setting\", Please check again
stevez97
Myrtle Beach, South Carolina
Trying to tweak my son's G5 that I originally programmed. Even without making any changes in Tab D4, I get the message, "[No. 698] All protocol is \"No Setting\", Please check again"
I never came across this before. What is causing this, and how do I correct it?
bob550
Albany County, NY
What change(s) were you attempting to make? What tab were you in when you received this message? Are you implementing encryption on the G5?
stevez97
I was in D4, desiring to add a P25 talkgroup. I had not added or modified a thing, however when attempting to move to another tab, I received that error message.
N6ML
Check row 698. You probably don't have a number specified in any of the ID columns (P25C TGID, P25T TGID, etc.). If that row is real, fix it. If it's not deal, delete it.
N6ML
Talkgroups are added in D5. D4 is only for encryption-related programming.
Prior to PPS V0.3.16.x, it D4 was "Group ID Setting". Unfortunately they inserted the new encryption tab in the middle, making conversations like this confusing.
stevez97
Yes............I was using a different version of the PPS, thus the variation of tab numeration. Sorry 'bout that!
Row 698 was absolutely the issue! (Learn something new every day!)
Now the cable isn't being recognized by the PPS. (It is by his laptop however.)
I think the drivers are auto-installed with Windows 10, but I'll hunt around to see what this solution is.
Thanks specifically to N6ML for the solution, and to all for their input.
