SDS200 No analog audio but Digital is fine
WD6ABC
Santa Ana, Ca.
#1
I've had more than one occasion where the scanner will stop on an analog signal (PL or no PL) and there won't be any audio
yet Digital decodes just fine. Power cycling the radio fixes the problem.
Using the most recent 1.10.00 firmware.
Anyone else experiencing that?
John B
kwebster7327
North Charleston, SC
#2
I've noticed that a couple times. Chalked it up to some kind of local signal noise at the time.
I can't repeat it. Not a show stopper, but I'd be interested in hearing an explanation.
Stockholm, Sweden
#3
Quickly turn down squelch to 0 when that happens, especially if you haven't set a fixed subtone, to hear if the signal are gone due to RF interference problems or if it is a squelch problem, that also could be due to interference that could create a broadbanded signal that triggers the squelch to close from the excessive high frequency components in the audio. You could also note the signal strenght indicators when it goes silent. Is it the same frequencies that have that problem? Then check their filter settings before power cycling and check if they are different after the power cycle.
/Ubbe
WD6ABC
Santa Ana, Ca.
#4
/Ubbe
I can change the scanner to the Weather frequency, see the high signal strength but no audio.
The scanner operates as usual when it stops on the Analog channel, just no audio.
Once I reboot it, the audio is back again on the Weather frequency and others.
John B
#5
John B
John B,
I'm experiencing the same issue, I think. I'll be riding along in my truck and notice that I haven't heard anything from the scanner in a few minutes. At a traffic light or other safe spot, if I look at the scanner I see that it is stopping on transmissions but no audio is present. I haven't messed with it enough to know if it is analog only or both analog and digital channels. I think the problem occurs on both since the scanner goes completely mute. My solution, like yours, is to power cycle the scanner which restores everything to normal.
Of course the problem showed up on the 31st day of ownership which means the unit will have to go back to Uniden instead of my retailer. I'm hesitating calling Uniden Tech Support since they already have my dead HP-2 (for the second time), so I'd be interested in hearing what ideas folks may have about what is going on.
#6
This is really bad.
Unlike watching a TV or listening to a broadcast music station where you would immediately notice no video or audio output, scanners are by their nature quiet at times and you don't know that you are missing stuff until you don't hear anything for a while and look to see it stopped but no had audio.
How often does this happen? Every few minutes or hours?
Hope this isn't going to be another common problem like the hum.
WD6ABC
Santa Ana, Ca.
#7
This is really bad.
Usually days.
John B.
#8
Usually days.
John B.
Mine is sporadic. Some days it won't happen at all (like today). Other days it seems to happen after 30 mins to an hour of operation. The other day it happened, I powered the scanner off then back on, and it happened again after approx. 15 minutes. Of course, this makes troubleshooting really, really hard ;-(
WD6ABC
Santa Ana, Ca.
#9
Today it went to distorted audio. (Listening to WX channel)
Tried changing Audio Off Time setting, Global filter. No help.
Only a reboot (power cycle or MSM command) fixes it.
John B
996XT
996P2
436HP
SDS200
