DSDPlus No audio on p25 version 268
bravo14
Polk County FL
It sees control channel and other freqs and tg. I’m running a laptop with win10 pro. Than last night I changed something than heard some garble wity full signal and than goes quite again. I’ll mess with it in a bit see why it do audio.
bravo14
Polk County FL
Step at 6.25 bw 9.5 gain 49 corr 23.0 here some screen shots
bravo14
Polk County FL
I went and tried another system and 935.450 audio came in good. The system I’m working on is 8xxmhz and I think the signal is weak on voice channels but all freqs come up with the tg
cg
Connecticut
- You could ignore the encrypted groups (Control menu)
- Gain may be too high. The signal strength is shown on the FMPx window. Bring the gain down until you see the floor stop dropping a bunch. For me, most of the signals work best with the floor around the second line.
- step is "[" and "]" keys
chris
bravo14
Polk County FL
The other day I did hear audio on p25 I guess the antenna I was using went bad. I ordered a new one also I think the sdr dongle is bad also.
bravo14
Polk County FL
I got the step to move. I am not able to move bandwidth... What is the command for bandwidth to change. Laptop won't load correctly it sits on 7.6 needs to change to 9.3 or 9.6 on the fmp24 side. Desktop works fine.
cg
Connecticut
Perhaps you didn't know that you can create (and print) text files with the various commands and parameters.
I created batch files to create these help files for each exe program as new versions are released.
dsdplus -h >DSDPlus_Help.txt
FMP24 -h >FMP24_Help.txt
FMPA -h >FMPA_Help.txt
bravo14
Polk County FL
I was able to get audio on p25 I went to Control Tab > Switch from CC Monitor 1 of 2 switch to > Combined CC/VC Monitor. Now when I go to a Cap+ System if I'm on CC/VC no audio I need to switch back to CC Monitor than audio comes back...........
cg
Connecticut
Is there a question there or are you just updating your progress from last month?
Mentioning one option you selected doesn't say what you have in the .NETWORKS or .FREQUENCIES files or what the batch files contents are. You would need to post additional information.
chris
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
I've read up on it. I was updating the list. In my area on Cap+ doesn't show network id.
That's true, but you need to assign one. You can assign a number that you want, but my post people just assign a Cap+ system a network ID based upon RR. No, RR doesn't list a Network ID either. But, in the grand RRDB this is a "system' and it's ID # in RR is 8454
Code:
https://www.radioreference.com/apps/db/?sid=8454
So assign this Cap+ system a network ID of 8454
Mike
bravo14
Polk County FL
Code:
Mike
I'll give that a shot. See what happens. In the note it does state use CC to hear audio.
