Put that in and still nothing on CommNet. i'm at a lost. I get it on my TRX 1 and my Unication g2 just fine but for some reason I can't get it at all on the 536
Double check which service types you have enabled. I looked at Jim's file & it appears that all the TGIDs are tagged as "Custom 1".
Are you using location control, either on the main database, or in your Favorites list? Is your location, and range, set correctly?
Here's a slightly different file, with location data in place, and with the service types as in the database. In addition to the statewide system (CommNet), I've also added the conventional channels listed on your county's database page.
Are you closer to one of the sites (on the state system) than the ones listed for your county.
