I have a Larsen tri band antenna mounted on the front passenger side of my ford f150 with a trunk lip mount. I'm having problems receiving medium range vhf signals and the close range vhf signals aren't as strong as they should. I've obviously determined this is a ground plane issue because my handheld pro-96 receives better than my larsen / 996xt setup. I can't mount to the roof because of clearance issues. I've seen the PCTEL Maxrad 144-174 No Ground Antenna advertised as 'not needing a ground plane'. Has anybody used this? Is this for real? If not, can anybody give me any tips or tricks on placing my antenna to better the ground plane. Thanks!
