No longer receive Tucson PCSO or TPD on SDS100
#1
For some odd reason, I no longer receive TPD or PCSO on my Uniden SDS100. I've not used it since the end of last year, so I'm assuming those frequencies have gone to digital encryption? The database and system is current and those frequencies are not avoided.
Thanks.
JPSan
Tucson, AZ
#2
Nothing has changed. I'm receiving PCWIN just fine on a SDS200 here in midtown Tucson.
You may want to reload ( refresh) your SD card .
#3
I just updated the system and card, but nothing. Looks like only P25 is functioning. May need a repair. I don’t think there is a way to accidentally block it in programming.
