No Mobile?
LATA 722
Many public safety radio systems are built to provide good in-building radio coverage. This benefits using a hand held inside a car. Works just fine, as long as you never stray outside the coverage of the radio system, and never need to work longer range simplex/mutual aid channels.
While not public safety, our 800MHz system at work has good enough coverage that most users only have a hand held. They don't need dedicated mobiles in the vehicles.
LATA 722
is this for cost saving I guess?
Yes. A Motorola APX mobile will run several thousand dollars, depending on the exact set up. Figure a few hundred in labor/parts for install. Multiply that savings by a few hundred vehicles, and you get the idea.
Steveradio
LehighValley/Poconos Pa
Depending on coverage areas terrain areas and what the car is used for nope, portable radio works well in most besides most officers forget to turn the portable radio back up when they get out of the car anyways.
ff-medic
Banned
The Appalachians - Next to the tent and campfire.
Portable only for dedicated detectives & investigators and the like would be ok. I always preferred mobile and portable radios together.
With the proper antenna and a good mobile you most generally can talk farther, and with less static and interference than a portable. Another benefit is that you can talk farther on simplex ( no repeater) with a mobile than you can a portable. Where I work our simplex conversations on our mobiles is much better than with our portables.
But in a mobile radio, I alway prefer and suggest a Vertex or Kenwood dual band radio.
FF - Medic !!!
phillydjdan
In Philly's case, when they first deployed the 800 MHz system, they quickly learned that the portable batteries only lasted half a shift. Officers had to call in via cellphone when their radio died. They now issue a spare battery with the radio if I recall.
captaincab
monitoring delco pa with gre psr300 pro2053 and b
Some districts do that when they have enough good spares they also have vehicle chargers in most district cars and epw's. Hopefully if/when the new system comes things will change and cars etc will et mobiles.
jeatock
090-45-50 W, 39-43-22 N
At the risk of offending the IT-founded communications managers and some members of the Law Enforcement community, there is a reason my firefighting bunker gear has both a belt AND suspenders.
"Stuff" happens, usually at an inconvenient time.
