No option to set priority after programming - Motorola XTS5000
XTS2165
We recently went through the P25 upgrade and now we can not program the second priority in our radio. If we are in programming mode and we choose sel, it will add to the scan list. But if you hit select again, it does not give you the "dot" or "blinking dot". Did something get deleted during programming? If so, I am not familiar with the configuration side, what should I reference in working with the person who configures the software?
mikev10
It's an option on the "General Tab" in the Scan List setup. Priority 1 & Priority 2 can be set to "Selected Channel, Operator Select, Disabled, or Fixed". The other Non-Priority members can also be set to Operator Select or Fixed. If you can "VIEW" your list and you don't see the blinking dot on any groups then yours must be set to Disabled for Priority 2. I would just ask if Priority 2 can be set to "operator select" in future subscriber re-programmings.....do it nicely they might work with you!!!!
XTS2165
Thank you!
Thank you so much for the information. We've given it to our programmer and he was excited to learn more and now we can set our priority 2 Channel!
Thank you so much!
