No power after repeater interface cable
sealer45
Hi
I was trying to make a repeater with two m1225 radios I bought a cheap interface cable from ebay came with no instructions so i plugged it in now no power to radios the rx had blue chip on it the tx did not Did this cable fry my radios? buy probably not plugging cable in write
thanks
Are you using factory power cables with an inline fuse? Check those fuses. If not it may have blown the Pico fuse inside the radio. Those cables have no orientation on them so it could be easy to flip them. Were they ignition sense before you hooked up the cable?
Sent from my VS987 using Tapatalk
sealer45
unfortunately i didnt have inline fuse there they were hooked up to my 30amp power supply Do you have any ideal were this Pico fuse is located in unit? I took top off but didnt see anything burnt
thanks
Should be near where the red power wire solders to the board. A diode will be near it. It looks like an all green resistor. Take your multimeter and see if you have continuity across it, or apply power and see if there is power on both sides.
sealer45
Ok thanks ill go get a meter and look at that Also Is there a way to bypass that pico fuse to see if it comes on? also if thats the problem what pico fuse do i get to replace it ? any i deal or if you know of a link to the fuse i need
thanks
You could bypass the fuse just to see if it works, tweezers always work for me. 2 amp pico fuse, would just grab some off ebay.
sealer45
Ok i must have screwed up bad using that cable I went and got meter set it to ohm with the buzzer on it no buzz on pico fuse power on or off also tryed your tweezer trick on each side of fuse still didnt come on
thanks
Are you sure you didnt accidentally hook the power up backwards?
sealer45
Positive i didnt do that I have been using the radio to talk on a gmrs repeater until i received my second radio i wanted try to set up my own for family use the only thing i did was plug that cable in and one radio set rx and the other set tx tryed to ptt radio didnt hear anything nor did my transmit light come on so i figured the cable was wrong so i flipped cable so both label were up saying rx tx still nothing so i shut it off and it would not power on either of them
sealer45
Also i want to say is im using a mjf 4230mv power supply 30amp hooked to it is a tenma dc strip 35 amp with amp meters 72-6627 now when i would ptt on m1225 my amp meter would read 10 now i have another radio tyt 9800 that only shows 3 amp on ptt i was never sure why that was just another thing to let you know i never ptt from second radio i set up so i couldnt tell you what that was amp was.
thanks
sealer45
voltage on power supply was reading 13.5 the radios did work also on the radio that was getting 10 amp read on ptt was set for tx i added a fan for cooling direct to power cable when i would ptt it would bog down like it was draining the fan would slow down so i unplugged fan to see what it would do did not fix it radio still powered down so i dont know if this amp rating had something to do with radios and or cable both i just crapped my when i ended up with over a hundred dollars paper weights
thanks
sealer45
N4KVE
I totally agree I never gave It a thought when I hooked it up my bad I learned a lesson that wont happen again on that
sealer45
Mcore25
I totally lost when it comes to circuit boards can you point in the the direction where voltage regulator is and do i use ohm on meter on it or what what is it suppose to read if it is dead does that pinpoint problem
thanks
WA0CBW
Shawnee Kansas (Kansas City)
It sounded like you used your ohm meter or continuity tester and turned the power off and on. You should NEVER have power applied when using those two devices.
Bb
sealer45
Thanks discombobulated
I got time today to go back through radios I dont know why it didnt work the first time but did your tweezers trick again and boom the radio powered on so I ordered a five pack of 2amp pico fuses on ebay for 5 bucks
Thanks again
