no recieve audio after programming Wouxun 3D HT.
ranger821
Fort Walton Beach, Florida
My buddy and I need some help. We finally got it programmed, but after that no receive audio. It is tranmitting no problem. Programming cable was not seated and that was cuasing it not to program. Any sugeestions, majic tricks, voodoo I can use on it.
John
fineshot1
NJ USA (Republic of NJ)
sounds like its possible some data got corrupted.
try writing the data to the radio again, and again if necessary.
not sure if that will help but i don't think it will hurt.
pointman1177
Metro Detroit, Mi
I have this same radio and had the same problem as did many others. Look it up on youtube as well and you'll get an answer. The internals are not aligned correctly with the case and once programmed for the first time disables all audio (tones, music, any possible sound). Send your radio back to powerwerx for warranty repair. Had I known about this earlier I would have never bothered with them and would have went to wouxun.us
I fixed mine the day I was going to send it back by plugging in a headphone jack and moving around the plug until it looked straight, then it miraciously fixed itself
This is not the first or last time this has happened to someone as you will find out, this is only a uv3d related problem as well
ranger821
Thanks Point man. My buddy is going to send it back to buxcomm for repair or replacement. Seems like there was a lot of the 3D's that did this. My 2D will be here today.
