No Squelch
The software has NO effect on the squelch there are no settings in wiin96 that will have anything to do with the squelch. what system or frequencies did you import if any?, in short the squelch has no software programmable settings. if ya like post your p96 file & others can look it over for you.
Paul
zzdiesel
Kennett / Dunklin Co, Mo.
The radio keeps the squelch turned off unless it runs across a programmed TG and then it opens it up and you hear it. It's the same way on conventional channels that you program with the tone codes.
RoninJoliet
ILL
There is no squelch on trunking talkgroups or digital trunking of talkgroups...Put in a conventional freqy like a ham freqy with "FM" selected and you should hear squelch....
