NOAA Mode
Skud
Middleville, MI-Barry County(Near G.R. & Ionia
I set my info in my Pro 96 for the NOAA for NWS SAME signal and have it in Standby Mode. While in Standby does it lock the scanner so I am unabe to listen to any others channels? If so is there any other way to still listen to other channels while being the Standyby Mode?
Shackman
kalamazoo, mi
you could set the weather channel as the priority channel. You do this by pressing function and then the priority button while listening to the weather channel. The problem with doing this is, if you are listening to a trunked conversation the scanner does not check the priority channel untill afterit resumes scanning, possibly causing missed weather alerts.
tbharper
Lafayette TN
ok i put the s.a.m.e codes in my pro 97 and pro 96. my question is when there is bad weather will it automaticly go to that code set for the county that has bad weather
ScanDaBands
Banned
State Line
Speaking of that , is there a spot on RR here that tells you how to set up S.A.M.E in the 2096?
rdale
Lansing, MI
SAME codes do not work while in weather priority... If you want SAME, you have to dedicate the scanner. Better to buy a $30 SAME radio and have it 24/7
ScanDaBands
Banned
State Line
ok Thanks 100%
bubbaearle
Arkansas
Pro 97 & 2055 SAME Standby
During the last big storm system that came through NE AR I had my wife turn on both scanners......I had her set the 2055 to SAME standby and use the 97 to listen to the local law........I was at work by the way
A tornado warning was issued for a nearby county and the 2055 went off....scared the hell outta her.....but it worked........that justified to her my purchase of those scanners.......she don't like fooling with them, but she has listened a few times with me when there has been interesting stuff going on......
I leave the 2055 on SAME Standby at night if there's a threat of bad weather in the area, that way it alerts us to any warnings.
ScanDaBands
Banned
State Line
Thanks for the input from all , appreciated 100%
Skud
I found out with the Win96 software you can enter the SAME codes for your county and turn on ATT. This can be on under the system/weather tab and these options are on the right hand side of the page. I am at work so I don't have the screen shot infront of me. On my Pro-96 the scanner says "ATTon" and it scans just like normal but if NOAA gives a warning I hear it.
ScanDaBands
Banned
State Line
GOOD INFO , thank you very much , give it a whirl on my 2096.
Skoz
I have a pro-96 too and whenever you are in NOAA standby you stay there and can't listen to anything else unless you press <func><wx>, or, you turn it off.
rdale
Lansing, MI
COMPLETELY wrong... The attenuator has nothing to do with weather reception - check the manual.
In any case, you cannot monitor SAME codes while scanning. I said that above, it was true then and it's true now. You can only monitor weather alerts for all counties / hazards. You have to dedicate the scanner if you want to filter for SAME counties.
