NOAA Weather Radio KGG68 info needed Tomball
Rick2010
Houston Tx
I am looking for current information on KGG68 NWS radio in Tomball. Looking for actual location, antenna height, transmitter power, polarization, ERP. It's not in ULS that I can find.
Thanks in advance for your help.
nd5y
Wichita Falls, TX
No federal stations are in the ULS because they don't require FCC licensing.
The NTIA GMF FOIA document from 2021 has the following.
I don't know if it's still current.
16000 BROWN ROAD 77377
30 05 47 N 095 39 23 W
A tower owned by City of Houston is there. It looks to be the same location shown on the NWR coverage web site.
FX 16K00F3E K1.00000
Fixed station running 5 kHz deviation FM at 1 kW (1000 watts)
also has other emission designators for the SAME data and tones.
08GDIPOLEARRY00069H0105T ND 1
It's probably a standard 4 dipole array non-directional
I don't know how to decode the antenna height.
I don't know if 08G is part of the antenna or some other field.
I can't imagine it being anything but vertical polarization.
The data in the pdf is not formatted properly and hard to read.
Echo4Thirty
Spring,TX
That is the old site on Brown Rd. They moved to another site a couple of years ago. Its still on the NW side of Houston, but I do not recall which actual tower.
Echo4Thirty
Spring,TX
I am about 75% sure. I had a conversation with NOAA awhile back and they said something about it since HC wanted to vacate Brown Rd for a tower that had yet to be built. I will go back and see if i can find the info.
I have not driven the site to confirm.
