niceguy71
I have always heard my radio make a noise getting louder in intensity and the S meter goes up to 5....6...7.......then fast to 8 and 9 .. then it pops and goes back to nothing and starts the cycle again.. it has done that on different radios... Cobra 148 President grant and now the Anytone 555 N II .... I have swapped out different power supplies and shut off all the fluorescent lights in the garage... it's always there... I have shut off all the circuits in the house but the radio one, and it still does it... so I live with it.
today I finally went out with 8 handheld CB's to try to get a 5 mile range test.... I know I will barely hear it if I can do the 5 miles.... so I put my Ecoflow Delta 2 Max on the work bench and plugged the radio into the cigarette lighter port... it took a minute but now the S meter stays on S2 and no slow build up and pop.... the EcoFlow says it will run my radio for over 99 hours and over 60 when I'm transmitting.... I think I'll just leave the EcoFlow battery back up generator right on the workbench from now on..... I think the noise is coming in from the street.
as for my range test.... I was forcing myself to go as nothing has gone right in getting it done in 8 months... just too much other stuff needing to get done..... I wanted to do it before the trees had leaves... too late now..... I wanted to go over everything but didn't have a plan,,,.... I have the 3.5 mile and the 4 mile stations at schools in the area nice wide open parking lots..... so I can only go on the weekend or on a holiday.... so I forced myself to get all the 80 batteries charged up and made myself go. .... but I was not happy or in the mood to do it..... I'm driving down the driveway and it starts raining.... don't care I'm getting it done.... first location the wind is roaring and blows the tripod over and damages my phone..... it now stops recording every few minutes???.....so I had to keep reshooting the videos... at location 3 miles from base station a huge gust of wind blows the tripod over again and smashes my expensive phone to pieces!
but I keep going and at the 3.5 mile location I keep hearing someone in Spanish on 14... I watched 14 for a 1/2 hour before I left the house to make sure it was clear....... but I transmitted on 8 radios... first low power... then high power then low power with the 51 inch antenna then high power with the 51 inch antenna... it was a 1/2 hour at each location... as I would say this is the Midland 75-822 on low power with 1.2 rechargeable batteries from one mile from the base station testing one two three.... then did the other three similar tests low high and I used the same 51 inch antenna on all 6 handheld other than the Randy and the TRC 216
I'll look at the camcorder that was watching my base station radio and see how it worked later and share the results.
