Noise on Transmit
03msc
RF is RF
Arkansas
I have a VX-351 portable that I use for work (simplex only). Most everyone else at work has a Motorola of some sort. When I transmit from my Vertex, there is a slight noise (hum, or something similar...though it's hard to describe) in the background. It isn't enough that it covers up what I'm saying but it's enough that it's audible. One of the guys here said, "I can always tell when you key up because your radio has a little noise in the background."
Any ideas? Is there something wrong with it or is that just the way it is? Slightly out of alignment or something?? After I was told about it I did some testing and if the radio is in scan it is even louder and has a little rhythm to it (like scanning I guess) but if not in scan it just is a steady noise.
Any help/insight/ideas/replies would be appreciated.
m-gerty
Miiddle TN
Are you using a battery or a battery eliminator?
Are they both programmed for narrow band, that will make it sound different.
Have you tried transmitting from a different location, to rule out background interference? Let us know what you've tried and give us more info, UHF/VHF.
03msc
RF is RF
Arkansas
First off, I mistyped on the model number...it's a vx-354, not 351. Full model number is VX-354-AG8B-5
Using battery only.
I'd have to check the narrowband...I believe so but that might be something to check.
It's UHF on our business frequencies (licensed) and it sounds basically the same on all 5 channels.
And no, transmitting from a different location doesn't change it.
Everything on the radio (battery, antenna, etc.) is stock.
Thanks for your response and feel free to ask other questions or give other input, you or anyone else.
03msc
RF is RF
Arkansas
Are you hearing the PL tone? That can sound like a low frequency hum. It may be that your Vertex PL tone is a little to "hot" (louder) than the other radios.
BB
Hmm...possibly. It's DPL 315 I believe...hadn't thought about that but do you think that'd be it?
I guess I could do a test and program one channel with no tone and see if the noise is still there...
12dbsinad
If it's DPL, you could be hearing the DPL "rumble". Some radios you may hear it very slight. But, do as you said, try it with no tone and see if it goes away. If it isn't the tone, try banging on the radio while transmitting. If the noise changes pitch or gets more severe it could be something internal like a ground pad or shield that is causing the noise.
m-gerty
Miiddle TN
If you transmit without a PL tone, and the other radios have them, they won't hear you at all. If they have a button programmed for "monitor" they can press and hold while you test. A scanner would work also.
