GKolo
BC350A That worked fine up until 3 days ago when it started picking up the whine of engine noise, It worked great till it started this, Nothing has changed with the motor, It has noise suppresion plug wires already on it.
Is there a filter anyone has used to cut back on this ?
I checked all conections and even added a extra ground wire from the radio to a good ground with negative results.
Radio picks up fine with the ignition in the off position.
If someone has a idea pass it along, Its like this just happened overnight.
