Noisy Waterbury
noobiest
watr ct
Has anyone noticed the loud and extended tones on several WATR PD frequencies? What is this? it seems to have started today.
firerick100
wolcott ct
i have not heard anything yet,i wonder if we can trnckck track it so we can just hear the fd or pd
noobiest
watr ct
Its been real quiet today and 825.1125 is locked on as if someones is on. At the bottom of radio display is an area that says search, on all the other freqs. but this freq. is saying P25:000
cg
Connecticut
P25 system is turned on but appears to be only for testing. 852.1125 was the CC last week. You should see 0097-0101 for sysid. Bandplan appears to be a bit odd.
Look for switch over from EFJ Multinet to P25 in next two weeks or so.
chris
cg
Connecticut
You will be able to if the talkgroups are not encrypted. I would expect the PD to have some, if not all, of their talkgroups encrypted. I don't have any information on that, just that I would expect them to. They are encrypted on their P25 channel now.
chris
cg
Connecticut
No list but the activity I saw was on TG 61. The Multinet layout put that as Fire Dispatch. It remains to be seen if they will be the same layout.
PD was 11-29
DPW and schools were 31-52
FD was 61-99
chris
izzyj4
Ova here
Are they using the same frequencies as before or have they adopted a new band plan?
cg
Connecticut
As I mentioned, only two channels are being used so far. They are both from the existing TRS. I don't know what they are planning, only what I monitored when I stopped by there and did a search. I friend mentioned that it would be around two weeks before they went over to the new system.
chris
colbyct
Middlebury CT
wtby
They are in the process of testing the digital system now. I don't believe that the PD will be encrypted but i'm unsure about that. i'm waiting to hear back from my connection in dispatch to find out more info. stay tuned
firerick100
wolcott ct
i tried to put the sytem in as a p25 system on my 396xt and there is no where to put the ids above,i wanted to monitor them to see what action was going on
cg
Connecticut
In a P25 Trunked system, there should be an option for Talkgroups. Enter 61 in as a talkgroup. Leave the radio in Search mode for others.
chris
noobiest
watr ct
I hope you guys are ridiculously simple in explaining what to do in future. I tried to enter a 097 something thingy instead of search and did switch to p-25, a few weeks back. That is now perm locked out due to it locking up system with silence. For now, I hear things as usual.
cg
Connecticut
You have some time before they go live, read the manual that came with whatever it is you were trying to program.
chris
firerick100
wolcott ct
the scanner ask for a band plan which nobody knows yet on the 396xt it looks like you have tochoose motorola system so you can put in the ids when they come available,,i tried it chosing the p25 system and there is no option topu t in radio ids,we will see what happens in a couple of weeks and then we can wor out the bugs in our scanners.
firerick100
wolcott ct
waterbury had a major fire today i listened to them while i was on scene i just monitored their freqs and i was picking up most of their communication, i had to lock out one freq it kept locking on-i scanned it conventionally,i cant wait until they switch so i can hear just them
