NWTSCL said:
Uniden should not trivialize everyone's $600.
How are they trivializing it?
Paul is actively working on a solution. He's not going to be able to pull one out of his hat, and the fact that he IS doing SOMETHING is much more than I can say about any other manufacturer or retailer I have ever done business with.
And yes, the cars analogy IS a good one. In the 80s and 90s, GM had a severe problem with paint flaking off their vehicles. It is not uncommon to see a GM vehicle from that era that is over 90% primer grey due to the worn-off paint. Your constant complaining is like a GM owner with bad paint demanding a solution 3 weeks into the production run. It just won't happen. How widespread the problem is has to be researched, as well as what the possible causes might be. That's why Paul is asking about any special observations or conditions in the thread about this issue.
If having the keypad wear off of a scanner indicates that it is 'broken' or 'nonfunctional', then all 5 of my Uniden handhelds and all 3 of my RS handhelds are all broken. However, every last one of them still receives and outputs the audio quite decently. And that's the purpose of a scanner.
I admit to feeling a little perturbed when I finally noticed that my 396 was suffering from the same fate as the others, but it's not something to have a stroke over. Besides the fact that 90% of the time it's going to be under computer control, so I don't intend to mess with the keypad too much and further wear off the lettering, I know that Uniden at least gives a crap about this and is addressing the issue, unlike for example my PRO-43, which was in the Intertan repair center 5 times for keypads that died, and all they would do is keep replacing it instead of finding the true problem.
I respectfully suggest that if having the legends rub off the face of your scanner poses an immediate problem which you cannot bypass and causes you to be completely and totally unable to use your scanner, perhaps you should send it back for a refund and try something else.
And by the way - if you paid six hundred dollars for your scanner, you got robbed.
