NON-STANDARD DPL TONES
nokones
Sun City West, AZ
I am seeing non-standard DPL tones being used such as D013N these days. As everyone is aware, D023N is the lowest in the Motorola DPL table in the CPS for every model series before the APX series.
Does anyone know of a procedure to manually enter a non-standard tone and will the radio firmware accept the change especially for the XTL and XTS series?
This must be a CCR thing.
mbnv992
AZ
Someone local to me is using that code ( 013 ) for a local GMRS repeater. Sucks since none of my Motorola radios have that code and it’s a really nice repeater with great range. I emailed the owner of the repeater that issue and he said he might change the code in the future. But for now - anyone with a Motorola radio that needs 013 for a repeater - not gonna happen ( at least not that I know of. If there is someone definitely tell me )
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
There isn't one.
The big three and the CCR companies include complentary codes for some reason. Motorola doesn't.
There is a complementary code to 013. If you use 013, it will false a different DPL code. I'm not smart enough to figure out what the complemtary code is with out doing some research first. I'm sure there is someone here that can tell you what the complemtary code is.
The 'standard codes don't have this problem and shouldn't false decode.
n7maq-1
Oregon
There isn't one.
Some Kenwoods will allow non standard DPL tones, I tried 013 and the service monitor decoded it as 013 so there may not be a "complementary" code. That said, one should not use bogus DPLs.
Jim
N4KVE
PALM BEACH, FLORIDA
Maybe that’s why the repeater owner is using that code.
rf_patriot200
Freeport, Illinois
Jim
Yes, I have 2 Older kenwood's that will do non-standard pl's and Dpl's . There are times where I can see this as being useful, even tho not the norm.
nokones
Sun City West, AZ
I just learned that my Kenwood TK880-1 will allow the non-standard DPL code. You click on the respective tone column and enter "D013" and tab off and it will populate the change. Then I wrote the change to the radio and tried and see if I could hit the repeater, surprisingly it worked.
I wish my Motorola radios would do that as easily that the Kenwood did.
AM909
Radio/computer geek
SoCal
Use of the non-Motorola-standard DCS codes pre-dates CCRs by decades, just like the non-EIA-standard CTCSS tones. Does it just not accept codes below 023, or not accept anything that isn't in the ~83 Motorola-standard DPL codes?
These should all be equivalent codes ("+" is normal, "-" is inverted):
+013 +063 +700 -376 -617 -763
Those pages on the onfreq site are a good resource.
nokones
Sun City West, AZ
The CPS uses two pulldown lists of CTCSS & DPLs for each the encode and decode to select the appropriate tones/codes. The pulldown lists will not allow any manual entry unless there is a special keyboard procedure to bypass that lockout feature such as control, alt, or shift function.
If there is an equivalent inverted DPL code for the normal D013, I sure would like to know what that inverted code is. I tried each DPL normal and inverted that is on the DPL pulldown lists and the repeater did not accept any of the Motorola DPL codes.
Asunakiyori
Lurker
Hiding in a Shed somewhere
Ima guess the repeater you are accessing is using is DXXXI or DXXXN? yea moto wont do those...
