Non-typical receivers
krokus
Southeastern Michigan
What sort of non-standard receiver do you use? The below quote made me wonder what people use, that is not meant for scanning/SWLing, etc.
HP 3586 will be a bit over the top of the $200 limit, although I bought my "A" version for NZ$100, say US$68, in non-working condition but now it works very well after some TLC. Not exactly a toy for the newbies though. I'm hoping to hear Grimethorpe SAQ next month on 17.2kHz - yes, 17.2kHz! Google for it......
I used to use the 3586 for monthly maintenance of an analog microwave link, and wondered about what else it could be used for.
I have a Frequency Selective Voltmeter that acts like a really good AM receiver from down near 0 up to 2500KHz. A bit too narrow for decent AM broadcast listening, but it is more selective and sensitive than anything else I've ever owned.
Was fun to listen to long wave beacons on it, and getting down into the weird stuff in the 40-60KHz range.
a417
I had this triangular shaped black AM/FM clock radio in the late eighties that picked up BBC Radio 4's MW signal in southern New England at night. That was pretty non-standard, as it had to be in cassette mode. If it was in AM or FM I'd get the local stuff.
RFI-EMI-GUY
I had an HP3586B. It was a very interesting receiver. But it lacked a practical AGC. So the audio level would ramp up and down. I thought about ways to improve that but eventually sold it off.
majoco
Stirrer
New Zealand
Yes, the 3586 series does not have any AGC - that's the whole idea, it's really a tunable voltmeter that reads down to -120dBm which is somewhere down at 0.2microvolts in 50 ohms and measure the frequency down to 0.1Hz . You switch it to any 10dBm segment, leave it to make it's own mind up or set to cover the whole range but - as you say - the audio jumps up and down as it changes range. Mine has the hi-stab oscillator so it can measure the frequency of WWV - which is usually spot-on! Did you know you can use it as a signal generator - carrier only of course.
RFI-EMI-GUY
Yeah the generator port out the back panel is a hidden feature. Probably because they wanted you to buy the pricey companion tracking generator.
KK4JUG
GA
I remember using a crystal radio (with the cat whisker) back in the Ozarks in Arkansas in the late 40s and early 50s.
(Yes, I'm old. I'm constantly reminded of it.)
RFI-EMI-GUY
I am interested in Aperiodic receivers.
Thinking of something modern 800 MHz, to detect transmissions and LO activity of common public safety radios. Sort of a police radio detector (Like radar detector-detector) . Once everything becomes encrypted on public safety, it would be a way to detect nearby police radio activity,
RFI-EMI-GUY
I used to listen to WOR NYC, Jean Shepard, at night using a crystal radio receiver at home in NJ.
GB46
Man, do I remember that! I did the same thing in my early teens, and stayed up late listening to his stories with my crystal radio's earplug in my ear, although I was in bed and supposed to be sleeping.
A few years later I was lucky enough to see him in person on the Rutgers University campus in New Brunswick, NJ. The student centre was filled to capacity. Someone came up on stage to announce that Shepherd had been delayed on the NJ Turnpike and would be arriving late. This caused an uproar in the audience, but Shepherd showed up right after the announcement and shouted through a megaphone ordering the audience to calm down.
Where did you live in New Jersey? When Rutgers wasn't in session I lived in North Brunswick.
RFI-EMI-GUY
Lawrenceville, off the Princeton Pike.
GB46
Roughly 20 miles from where I lived. I often went down to Princeton via Route 27, but never got as far as Lawrenceville. The town's name is vaguely familiar; I think I remember hearing about some kind of annual carnival there, but maybe I'm mistaken.
krokus
Checking for traffic on repeater inputs could work. A trunk tracking system could be modified for that.
RFI-EMI-GUY
That very idea crossed my mind. I have a bunch of 800 MHz repeater preselectors. Add an LNA , RF gain amp and a detector. Ebay has all the parts needed.
ridgescan
San Francisco, Ca.
Not sure what you are referring to band-wise far as "receiving". The only two receivers here I can think of as non-typical for a given application, would be my old Ray Jeff RDF portable that uses MW carriers to direction-find. But it happens to be a great long-distance MW station getter.
The other is my Icom R75 that is normally mainly an HF rig but since it has scanning capability and FM mode, I happen to scan the CHP across the Bay Area in the 42mHz band. IOW I use it as a scanner occasionally.
Token
I have used several different spec ans for receivers, sure, the 3586, but also things like the HP 8566 or 8568, HP8553 or HP-140. Recently I have used both the Rohde and Schwarz FSW-43 and FSWP-50 as receivers. Both they and things like the Tektronix RSA-518 allow I/Q recording of spectrum, so that you can capture chunks and play it back, like many SDRs.
I pretty regularly use things that are receivers, but uncommon to find today or in an unusual application. The AN/APR-1, APR-4, APR-4y, and APR-9's all get fired up here at the house on a regular basis, sometimes to be used as is, sometimes as down converters to other radios. I have used an AN/WLR-1 to monitor 2 meters and 70cm, as well as the FM broadcast band. I have listened to police transmissions using an AN/SLQ-32.
I have used radar front ends and antennas to monitor non-radar stuff. Use the antenna and front end of the radar, and then put a more traditional receiver (or spectrum analyzer as described above) on the IF of the radar, allowing the receiver to leverage the antenna gain and use the radar front end as a down converter. I have used an SCR-268 (a very early WW II vintage radar) antenna and front end to down convert 2 meters to an HF radio. I have used an AN/TPS-3 (SCR-602) the same way. Those are notable because of what the radars are, both of them being very early radar that essentially will no longer be found. At one time I used an AN/TPS-1D as a front end to monitor 23cm.
T!
