Original poster, it looks like you are from Ossineke? That appears to be in Sanborn Township in Alpena County, Michigan.
Were you able to do any research on this radio to see if it would work in your area as it is an older radio originally made by another company?
It would appear that Alpena County uses MPSCS Phase ll TRS. I'm not familiar with your neck of the woods but just to let you know your radio is not capable of picking up phase ll transmissions.
If you bought the radio from a reputable vendor there should be a 30-day return period.
You will want to do research on buying a phase ll capable scanner that works well on phase ll.
Check out your state forum in Michigan and see what other users say about MPSCS and what works best for them, especially if there's any situation with simulcast distortion, you are limited then to just a few radios that will work properly.
There should be much information on this system in the state forum for you to read and do research. Good luck.
