blackglock40
my set is pretty basic compared to some here. i mainly listen to my scanner which has a cb
feature.
looking for advice for future installs.
here are my pics:
http://pg.photos.yahoo.com/ph/adamwnc28471/slideshow?.dir=/bc66&.src=ph
http://pg.photos.yahoo.com/ph/adamwnc28471/slideshow?.dir=/f500&.src=ph
my set up:
a work in progress
Radio shack pro- 2051
Pro-2051 1,000-channel,
triple-trunking scanner from Radio Shack. Signal stalker
allows you to lock on frequencies within 1,000 feet, without
programming. The PC interface lets you program your
scanner using your computer. Support for Motorola, LTR and
EDACS trunked systems permits you to access most any
police, fire and emergency system. With built-in Skywarn,
you will be able to stay up to date with the reports called in
by storm spotters.
Band Frequency Range (MHz) Mode Step Display
1 25.0000 - 27.9950 AM 5 kHz 25-28
2 28.0000 - 29.7000 FM 5 kHz 28-30
3 30.0000 - 49.9950 FM 5 kHz 30-50
4 50.0000 - 54.0000 FM 5 kHz 50-54
5 108.0000 - 136.9875 AM 12.5 kHz 108-137
6 137.0000 - 143.9950 FM 5 kHz 137-144
7 144.0000 - 147.9950 FM 5 kHz 144-148
8 148.0000 - 174.0000 FM 5 kHz 148-174
9 400.0000 - 419.9875 FM 12.5 kHz 400-420
10 420.0000 - 449.9875 FM 12.5 kHz 420-450
11 450.0000 - 469.9875 FM 12.5 kHz 450-470
12 470.0000 - 512.0000 FM 12.5 kHz 470-512
13 806.0000 - 823.9875
849.0125 - 868.9875
894.0125 - 956.0000
FM 12.5 kHz 806-956
14 1240.000 - 1300.000 FM 12.5 kHz 1240-1300
Icom r-10 1000 ch communications reciever
Vintage: 1997
Type: Handheld
Range: (U.S.) 0.5000-823.999, 849.0001-868.999, 894.0001-1300.0000 MHzChannels: 1000
Banks: 18
Modes: AM, FM, WFM, USB, LSB, CW
Priority: 1 channel
Conversion: Triple Scan: 6 channels/second
Search: 17 steps/second
Audio: 120mW at 10% THD
Power: 4 AAs 4.6-16V DC
Size: 2.3"(W) x 5.1"(H) x 1.2"(D)
Weight: 10.9 oz
Interfaces: BNC, speaker, CI-V, DC
Accessories: Antenna, belt-clip, hand-strap, AC adapter, 4 AA ni-cads
Features: VFO, band scope, auto-store, SIGNAVI, alpha-tagging, AFC, NB/ANL, search-skip, S-meter, attenuator.
radio shack radar
sirus xact plug and play
nmo antenna -VHF 1/4 WAVE NMO 136-174Mhz ANTENNA with TRUNK MNT BNC
WHELEN POWER SUPPLY VPPS2E
AND 2 REMOTE STROBES
and just added a
cheap uniden cb with a pa - for pa use only
no antenna.
i also use the pa horn for my scanner when im washing or doing maintenance to my explorer.
feature.
here are my pics:
my set up:
a work in progress
by storm spotters.
849.0125 - 868.9875
894.0125 - 956.0000
FM 12.5 kHz 806-956
Vintage: 1997
Type: Handheld
Banks: 18
Priority: 1 channel
Weight: 10.9 oz
radio shack radar
and just added a
no antenna.
