Nooelec and op25
Watton925
I have op25 running fine on rpi4 with rtl-sdr v3 but when I switch it to my nesdr smart I get nothing and I have blacklisted the drivers they recommend. Same nooelec dongle works fine on windows computer. Any help??
boatbod
Talbot Co, MD
Check the 'dmesg' command to see if the device is having issues. I've experienced USB connector failure with some of mine, even when using extension cables.
Watton925
Well I can see from the plot that I’m getting good signal but op25 seems not to see it could it be some thing in my command line I use to run it ?
Watton925
./rx.py --args 'rtl' -N 'LNA:36' -S 960000 -f 453.4750e6 -l 'http:0.0.0:8080' -o 25000 -q -2 -O hw:0 -x4 -T trunk.tsv -V -2 -U 2> stderr.2 This works fine with rtl-sdr v3
a417
U+0000
are you intentionally applying a -2 offset to this new dongle as well?
remove "-q -2"
boatbod
Talbot Co, MD
Please post a screenshot of the mixer, datascope and constellation plots along with any relevant messaging in the stderr.2 logfile.
maus92
The OP
especially the unpowered simple extension cables, the active cables have given me more success.
I must have purchased good ones - I use 10' unpowered USB 3.0 extensions and Nooelec SDRs with no problems. The Nooelecs are 0.5ppm error, so they need little correction; mine don't use any. My RTL-SDR v3 are ~1.0ppm.
a417
U+0000
I have one good 10' extension as well, the problematic ones are the little cheapo 1 to 3' disposable ones. For distance runs of 10' or more, I was referring to the powered USB repeater extensions that go out to 30' w/o an issue...
Watton925
My next issue is how to port the audio to Bluetooth or to my usb sound card correctly it works fine thru HDMI
Watton925
No it is not headless I’m pretty sure it has to do with the HW value can not figure it out.
a417
U+0000
What bluetooth stack are you using? Bluez w/ PulseAudio?
