Norman's bad dispatcher mic
n5bew1
norman, ok
For the past few months one of Norman's Mics or mic/headset(I don't know what they use )has had a bad connection or bad wire. Their audio breaks up badly when they use it and the usual reply is you're 10-1 and that is usually as far as it goes. Maybe someday they can find out which one has the problem and fix it or trash it.
plaws
O-o-o-o-o-o-o-klahoma
Do you have a tapped scanner? If so, you could watch unitrunker and try to figure out which console it was. :)
n5bew1
norman, ok
Nope don't. Short of calling 911 and telling them which dispatcher has the problem I don't know and I don't want to disturb their castle for that.
n5bew1
norman, ok
If i ever hear it again, i'll let them know. I havn't noticed the problem in a while and i listen quite often.
Sounds good to me It still pops up some days and you'd have more stroke than a civilian in letting someone know..
n5bew1
norman, ok
Well the guy dispatching for PD tonight just had his audio break up badly at 5:50 PM just about 10 minutes ago.
