karaoke100
- Joined
- Aug 25, 2009
- Messages
- 3
did north providence fire change frequencies? if so can you give them to me? thanks
do i have the right scanner
Hi, Ken, they have been using 154.800 MHz for months - the old NPPD frequency, because the radios operated better there. The PD went to the 800 MHz trunked system, encrypted. About 2-3 weeks ago NPFD went to this system, also, but simulcast on 154.800 MHz still, but now it sounds like s*** - muffled. Eventually they will pull the plug on that. And Providence FD went to this system and already pulled the plug on 154.370 MHz. I have an 800 MHz handheld scanner, but not digital, doesn't handle trunking. My mobile and base scanners don't do 800 MHz at all. So I have to upgrade everything. When you do, specify a digital 800 MHz scanner with trunking. You enter the frequency (868.7125 MHz), then enter the talkgroups that you want to listen to. NPFD is TG 1548 for dispatch.
rescueranger1982@yahoo.com post #260 on page 11.
Bob L.
What type of trunking system do I select for my scanner? MOT 800/900, EDACS, P25? I'm not picking up anything on the MOT 800/900. Not sure if it's due to range, or wrong selection of TSYS.
Uniden bc350 is the scanner i have, it has 800mgh channels but i don't know if it is digital
