north to south
tcb4ep
Wagoner, OK
i have question,, my radio is programmed for northern activity which reachs 40 miles. would i be able to accomplish the distance if programmed for south activity?
zz0468
Banned
I'm afraid your question makes absolutely no sense at all. Could you rephrase it?
tcb4ep
Wagoner, OK
ok.. if your antenna is the center of a compass and you are receiving signals north of your center location. in theory,. would your antenna pick up the same distance south of your center point,.
blueangel-eric
Emporia, KS
everything created equal the reception would be the same distance in any direction with perfectly omnidirectional antenna but with buildings hills and trees it varies. and if a omni is side mounted on a mast or a tower that might affect it some.
zz0468
Banned
Unless there is something blocking the path, you should.
Or unless it's a directional antenna, or something about how/where it's mounted MAKES it directional. But he did spell out omni in his initial post.
