I have searched the FCC ULS database and programmed all of the Active license frequencies for NOVEC. Nothing heard. Anyone with info on where NOVEC operations may be heard?
All I have heard for two days is occasional telemetry bursts on 173.39625 (173.395 programmed into the radio)
That is probably not a voice frequency. Do you have a radio that can listen to DMR? If not, you are probably out of luck.
Here's the license for what I believe to be a MOTOTRBO IP Site Connect system:
https://www.radioreference.com/apps/db/?fccCallsign=WQKQ612
153.2000 has the characteristic long data bursts for IP Site Connect.
Dave
I have the freqs for this license programmed into my 436 & 536 as conventional and trunked. I hear nothing either way. I haven't analyzed this system using DSD+.
Is this type of system able to be listened to?
