Northumberland County Fire
acre
Hi everyone,
I was wondering if anyone from the above location knows what happened to the fire channels for Port Hope, Haldimand Township, Grafton, Cobourg, and other surrounding areas? I'm only receiving Hamilton Township but no other fire channels.
I'm still using a Relm HS200, so I can only receive the fire channels. I've thought about moving to a new digital scanner but am hesitant because everyone is becoming encrypted!! Thoughts?
Many thanks.
gary123
Very few if any local fire services are encrypted. EMS is not encrypted and currently OPP is not either.
I suggest a current bearcat or whistler unit as many fire depts are using TRBO. Check the database for your local info and go from there.
acre
Thanks Gary. What is TRBO? There are so many terms I don't understand.
acre
Thanks guys! I figured the fire departments had gone digital Looks like I'm shopping for a new DMR scanner.
sirsmiley
Ontario
Or pick up a USB RTL dongle for 10 dollars online :)
(or a discriminator tap on an analog scanner with those frequencies and let your PC decode the DMR/TRBO that the scanner is sending to it)
https://goo.gl/vnuZxS
