*Not an Ad....Glenayre
quarterwave
TBD
Does anyone know if there is still a market for paging stations? I have access to a GL-861 VHF Station with Zetron 66 and mathcing 64 (that needs fixed) that is out of serivce.
I am guessing it is a lost cause. I keep an ear on 2 way....but I have no idea about paging....only that most of the paging freqs I know of are quiet these days.
Thayne
Probably not; not enough Glenayre stuff around and what I have seen around is pricey IMHO.
I have parted out about 5 900 MHZ 500 watt ones, not much interest except in the power supplies, RF decks & the racks.
I modified one of the 26VDC power supplies, it will run 90 amps continuous and is regulated too. I feed 4 solar type battery chargers I got free with it & have 12-15 VDC out the wazoo.
Only trouble is the transformer hum. Usually run on batteries except when charging about 3 hrs daily.
quarterwave
TBD
I just hate to see equipment go to waste. It cost this company $25,000 12 years ago and they used it for 3-4 years and pulled the plug (it replaced a 1/4k Micor type)...but paging was a good business until good portable cell hones and better coverage took root. They couldn't have know that for sure then.
Have 3 - 250 and 330 watt VHF's going to to the recycling center....junk now...but many years of service in IMTS and Paging.
WayneH
Forums Veteran
Super Moderator
Your master site
Per a USA Mobility pager tech I talked to they bought out Glenayre and all the rights to their equipment. They still use and repair a lot of it, especially on VHF (152MHz).
k8zgw
Macedonia Ohio
There may well be interest in the amateur radio market.
A 1/4 K amp, loafing along at 100 - 150 watts will play a long time.
Not going to command the bux it once did, but better then the scrap heap.
