It took some effort but I was finally able to get this thing to charge while turned on....
When the unit was sent to me by a friend as a loaner to test, he didn't include the USB "parts" (maybe assumed there was nothing special about them - obviously, that isn't the case.).
A few days ago, I finally dug around and looked at my various USB/AC adapters and most are 1A (some 0.5). Eventually, I found a unit that claimed to provide 2.1A. That one seems to work and I finally started seeing charging while powered on (red to green LED).
However, I took a drive yesterday and things stopped working again... Initially, plugged into the cig lighter USB in my truck, the radio showed red (charging) while powered on. I made a few stops and at some point, the unit stopped displaying any led (red or green). Of course, with the summer heat, the radio was even hotter than the normal "heat" I see coming from the unit (under normal conditions, the hottest parts seem to be the metal ones - antenna connection, USB mini plug, etc.).
Once I got home, I immiediately plugged the unit back into the 2.1A USB device that worked previously.... still no charging indicator.
The radio has been plugged into that unit all night in the house (72 degrees) and, aside from being generally silent and receiving nothing at that location, there still is no indication of charging status.
I powered the radio down and the RED led came on almost instantly.
Powered it back up and again, there is no LED.
And now the strange part - decided to verify that the "Charge while powered on" was enabled - it was NOT. Somewhere along the way, it seems that setting got changed to DISABLED.... no idea how or why.... I enabled it and now the red LED is once again lit.
FWIW - I'm running the latest beta f/w
