Not charging
godskidz
Bartonsville Pa.
Hi to all. My BC 246T won't charge my batteries anymore. The switch is set to NIMH.
Any ideas. Thanks.
dave3825
Suffolk County NY
Do you have a multi meter? I would start there to see if any power is coming out of the charger..
UnidenSupport
Uniden Representative
Wisconsin
Definitely flip that switch a few times. The first and most likely case is that the batteries are bad, after that, it's that the charger is bad, and if neither of those are true, then it would be a problem with the scanner itself.
