spanky15805
- Joined
- Sep 18, 2004
- Messages
- 306
I might be way off base but doesn't Greece use 8.33khz channel spacing? Might be a very small part of the problem. Didn't see any of the 8.33khz offsets in any of the videos.
https://www.eurocontrol.int/sites/d...n/files/201707-8.33-vcs-user-handbook 1.1.pdfTrying to find the info for EuroControl that is current isn't easy. Everything 6-8 years old. I know it was mandated for everything above FL195 in 2009. Plus he has some big hills between him and 2 of the 3 airports he wants to listen to.
Yes I have done this nothing changes really only the way you hear the signals, it changes only the modulation.You can set wide or narrow filter for both FM and AM mode. Try to change that setting.
Yes there is but it needs the adjust rig which it does not come with the purchase of the machine and of course i don't have itThere's a service mode, hold in two buttons at power-up,
If by the mean of hot spot you mean thisthen yes it's most probably tv or radio.
That's definitely for sure I've got to start from somewhere, have you got any suggestions for a man living in E.U?So an FM band-stop filter may be in order to at least see if part of the problem can be eliminated?
It attenuates the signal to less than half in the air band and only attenuates 6dB at 104MHz. Get something like this: FM Notch Filter, FM stop band filter, RTL SDR T820 Flightaware ADSB 2m 70cm | eBay or this: RTL-SDR.com Broadcast FM Band-Stop Filter | eBay and get som coax with the correct connector at the ends, or adaptors. 20cm RG58 Kable BNC Male Stecker To SMA Male Gerade Crimp Coax Pigtail 20in FG | eBayThat's definitely for sure I've got to start from somewhere, have you got any suggestions for a man living in E.U?i mean is this filter going to help?
It seems that they only use 8.33 at high altitudes in EU where aircrafts have a huge range with their transmissions. At lower altitudes used for approach departure and local control to a tower they assign a 8.33 label that are 5KHz off from the 25KHz bandplan, but when I checked two of those they where spot on to the 25KHz bandplan and not 5KHz off. So usually no reason to not use standard 25KHz bandplan in VHF air in my area and any old scanner/receiver can be used.Over here nobody is concerned about those steps.
