Not Hearing Flower Mound
ckqualls
Dallas
On my BCD536HP, I've programmed Flower Mound. I also have Flower Mound on Broadcastify. On Broadcastify I hear Flower Mound PD, but nothing on the scanner.
I looked at the groups on Broadcastify, and looked on the scanner, and the same groups are in the scanner.
I have Lewisville Simulcast and Denton County Simulcast both programmed in.
I pulled it from Sentinel, and updated Sentinel, still nothing.
I'm in Flower Mound, so in range of the towers, good signal strength on the display.
Any ideas?
BenScan
D/FW
Probably simulcast distortion(search the forums for numerous other discussions on the topic). You might try moving the antenna. Unfortunately, that scanner does not handle simulcast well. Double-check your squelch also. Mine is usually at 2.
ckqualls
Dallas
Probably simulcast distortion. There's a tower in Denton, one in Lewisville, both pretty close to each other. I imagine the Denton County tower isn't far from me.
Thanks.
Alliance01TX
DFW Texas
Howdy - You might try attenuating the signal to see if it makes a difference or not...try different location(s) in house / year or drive test as options to confirm you are getting anything...always double check the Service Types in case they were accidentally turned off...
ckqualls
Dallas
Well, in Sentinel, I changed digital threshold mode to manual and set digital threshold level to 6.
I started receiving transmissions. On Broadcastify, the transmissions come across a few minutes later, so I guess they are delayed there.
IAmSixNine
Dallas, TX
On my 436 i would run digital at manual and 8. But glad you are able to get reception again. Keep in mind that if you move around you may loose signal again as the system your monitoring is simulcast.
ckqualls
Dallas
Thanks. It is a base station so doesn't move.
Thanks to everyone for your help.
hiegtx
Dallas, TX
You might try a paper clip antenna.
Paperclip antenna
Basically, you have such a "poor" antenna that the out of sync signals from other subsites are too weak to affect your reception. The disadvantage is that with a poor antenna, systems farther away might not be received as all.
I'm monitoring NTIRN with several older models that are not 'simulcast friendly'.
My 325P2 has one of the Diamond RH771 antennas on it. But I have the scanner laying flat on my computer desk. It's getting probably 50$ or so of the calls.
One of my 436HP's is next to the 325P2, with the same antenna, also laying flat. Compared to the SDS200, a couple of feet away, it's getting 60 to 70% of the calls. I have a number of other systems programmed in both of these scanners, so neither is 'parked' on NTIRN.
My other 436HP is on the nightstand in my bedroom. It has one of the older 'OEM-Hears Nothing' antennas, and is vertical. It's in the 80% decoding range compared to the SDS100 next to it.
Also in my bedroom is my HP-2. It also has one of the Diamond antennas, with the antenna laid flat. It's probably 60% decoding range. Not getting everything, but still enough to be useful as an addition to the other two scanners (SDS100 & 436HP) sitting near the HP-2.
billpritjr
Dallas, TX
Any ideas?
If you are physically in Flower Mound and will be there most of the time that you intend to monitor the PD, monitor only 859.2875 as the ONLY freq, and ONLY monitor Denton County simulcast. Do not monitor Denton City, do not monitor Lewisville simulcast.
Keep your good antenna set up and try this first.
That should do the trick
- FM listener myself
