Not paging after firmware update
tcfcGreg
Updated my G5 to 1.3 last night now my pager isn’t alerting to my tones... what did they change that I have to fix?
amys17
East Sparta, Ohio
They made some adjustments to tone durations on the p25t side. Is that how you guys page? Check your minimum lengths of tone a and tone b and compare it to your old file.
RBMTS
Did you backup your Gx radio with the new PPS BEFORE you used the firmware update program? If so, then everything should have remained the same with exception of the new features. I'm starting off with the most obvious question before going deeper. If you did back it up, bring up your profile in the new PPS, review it to make sure that tone settings, zone and switch parameters are the same. Then try reprogramming that profile into the Gx. See if that works.
tcfcGreg
sorry i havent replied sooner been busy.... i didnt back up the radio on the new PPS before hand....
but on our thursday night monitor tone test my "all call" paged just fine neither of my 2 two tones signaled at all....
