I have been getting great traffic on evevrything except State Police. I live in VABCH. Any help would be great.
I have been getting great traffic on everything except State Police. I live in VABCH. Any help would be great.
Any luck, yet? I don't have a Uniden, so my help is limited. Are you downloading STARS from RR's site to your software or are you manually inputting into your software? Also, I am assuming you are picking up the CC. What kind of signal/ decode rate are you getting from that?
It looks like Chesapeake has 2 CC's plus an alternate. Have you tried all three? If you are receiving TG's good at one location and not another it does sound like it is an issue with decoding the CC. Have you tried other antenna's? My experience with digital trunked systems is basically all or nothing and that it is not hard to interfere with the digital signal to the CC.
try searching in the fcc db and see what the exact frequencies are for the tower in chesapeake cause you could be hearing bleed over from another site on the freq you listened to last night and search the area in the fcc database something in the rr db could be wrong. i can relate to that last thing for the odom site in northampton the fc db had it as like jackson site and i programmed the jackson site in and it was decoding as odom so someone screwed up somewhere maybe the same here?
You may want to also try to search between 150-162 mhz and see if you can find an active STARS control channel that is better than what you are getting.
