I am not sure how to program talkgroups into the scanner, but San Mateo also has talkgroups as far as I know, and I receive all the sheriff, PD and fire with no problems
I went to the Contra Costa county section, with the Calif map on the left side, and just below that on the first listing it says Contra Costa County, then below says Sheriff. then court security channels
I scroll down below that and ther is NO listing that says Contra Costa County Sheriff. Only listings below show all the individual cities, fire dispatch, BART Also, these listings just show the type, mode and tags of the listings, and no sheriff listings, other than the prison listings at the top under law tac. I am primarily only interested in San Ramon when visiting my friends, and Dublin where I travel through when going to or leaving, and Dublin is under Alameda County. I wish there was a away that someone could look at my profile that I sent earlier and edit it or tell me whiat I need to un-avoid. I appreciate everyone's help and patience with this.
That note under the
Sheriff header is indicating that the Sheriff's Office is not using conventional frequencies. Instead, they are using that linked trunked system:
East Bay Regional Communications System (EBRCS) Trunking System Profile
www.radioreference.com
These are the talkgroups listed:
Looking at your file, you do not show Contra Costa at all. Nor do you have Alameda unless those counties are in separate Favorites lists that you did not attach in your first post in this thread.
You can easily either, or both, if these counties using Sentinel.
Go to the database section in Sentinel
Click on USA to expand the list of states.
Next, click on California to expand the list of Counties.
Scroll down to Contra Costa, and expand it.
Click on the County Systems folder:
The Contra Costa in the right side pane has the conventional frequencies shown on the county's
database page.
If you select Contra Costa and,right><click. on it, you'll get a pop-up menu where you can select to Append it to either an existing Favorites list, or create a new one,
Similarly, if you select the East Bay system & <right><click. on it, you can append it to a list as well.
Both Costa Contra and Alameda Counties have talkgroups on the East Bay system.
If you also wanted the conventional channels for Alameda, click on that county, then on the County Systems folder to get a list of systems in that county. The entry
Alameda is the one you would want to append.
If you append all of these, you'll likely end up with things you do not want. Those can be deleted either the Favorites list editor, or by right=clicking on them in the main Sentinel window & choosing the option to Remove from Favorites list
