BCD396XT/BCD996XT: Not Receiving Trunking
drayd48
I have had my Uniden BCD996XT scanner for several months now. I got it because the audio sounded better then my RS scanners on my feed. I programmed it up and it sounded better on my feed than my RS scanner but did not pick up as well. Well, I just scan a single site system that I have been scanning the whole time without any problems. Just about a week ago, it completely stopped trunking or something. I factory reset the scanner and reprogrammed it with no luck. The scanner when scanning goes to the trunked channel that is active, sits there on the channel while flashing the CC and the voice channel back and forth but there is no voice. The scanner picks up VHF conventional channels just fine just not P25 trunking. If anyone knows a solution, please let me know, because I would like to get my feed back uo. Thanks
ofd8001
Louisville, KY
Any chance they may have changed control channel frequencies?
Is this a simulcast system?
drayd48
Sorry for the late reply. No. The CC has not changed. I have tested it on my other scanners and radio that I have. It is a one site system (well, there is really 2 sites, but I am only scanning one) and each site has different CC and VC's. It has just stopped trunking.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
It would help greatly if you would tell us what trunk system you're trying to broadcast and hear...Mike
drayd48
Sorry. It is the Statesville TRS East site. Only scanning Fire channels.
ofd8001
Louisville, KY
Next thing I'd suspect is that something has been inadvertently turned off/locked out/ etc. For example, touching the wrong number on a keypad could lock out a site.
I'd try reloading the programming files.
ka3aaa
middletown, pa.
make sure you are only receiving one control channel. If there is signal strength on more than one channel lock them out one at a time until it starts to receive.
drayd48
I did a factory reset on the scanner and reloaded the program files, then that did not work so I factory reset it again and programmed by hand and it did not work.
drayd48
I am only receiving one control channel. I only have the one in all my scanners because the other site is across the county for me and I don't pick it up good.
UPMan
In Memoriam
Arlington, TX
The symptom you describe in the first post is what will happen if there is no signal on the voice channel when the scanner follows the channel grant. On Motorola systems, this commonly happens when the wrong band plan is entered. However, on most P25 systems, the band plan is sent out over the control channel, so this should not be the issue.
If you manually park on one of the voice channels (i.e. program it conventionally) do you receive the voice traffic?
drayd48
Well, you were right. This is a real funny system, and I forgot, it took a while to get set up on my RS scanners. I had to put the system in my RS scanner as a P25 manual instead of auto. This TRS does not run any trunking tables. I went in a zeroed out all the band plans and it works great now. Thanks for all the help. I do also believe the Statesville runs an EF Johnson P25 system (saw it somewhere) and they operate differently than Motorola systems. Thanks
drayd48
Ok. My scanner is doing it again (except I knew how to fix it this time). The scanner automatically keeps changing its band plans to some 336 MHz channel and the scanner does not receive anything. Is there a way for the band plans to not automatically change. the system I am currently has NO band plans and works fine when everything is 0ed (zeroed) out and I have no band plan in. Thanks
