jsted2 said:
I was wondering why I can't pick up any of the DC channels. I loaded all the freqs. from this site with arc996pro into my scanner. I have had no problem with any other county in the Metro Area. Any help would be greatly appreciated.
DC Fire is your **standard** 800 MHz digital system (do not choose APCO25). If that is not the case, I have the feeling that when you say you loaded "all" the channels from this board, that may be exactly what you did. If so, please remove the 460's frequencies, as they are a seperate system for DC Police. Naturally, if you did load all the freqs, and put the 460's first, what is probably happening is that your scanner is locking onto the 460 control channel, and not giving you anything since you are looking for DC Fire talkgroups (also, the 460's require two custom tables).
However, if I have been wrong thus far, please post a little more on what you have loaded. This is a great board, and I have no doubt that we'll work with you until the problem is resolved.
Dewey
