Unitrunker Not showing all radio id after site enabled active radio aliases
PMDL4K1
Roytal Alberta
Monitoring a 700 mhz province wide harris trunk p25 phase 1 radio system with latest UT in Alberta Canada
Post site enabling active radio id aliases any dispatch radio source label and brief are blank with a radio id of zero
I switch to a site nearby that has not been updated its fine
Anyone else seen this
PMDL4K1
Roytal Alberta
signal is great on both sites, i found out the problem is known on Harris p25 system, in my case after the local site was updated
The nearby site was updated today and seeing same issues
Will wait to see if UT address this
dave3825
Suffolk County NY
What version of UT are you using? Have you posted in the UT Google group or reached out to the author?
Hi. dave3825
Yes, Rick=Unitrunker is aware of the changes L3-Harris has made to their new P25-P1 and P2 control channel messages and he is working on a solution. The new Harris control messages do not include the dispatcher RID information and Unitrunker is unable to decode what is not there.
There are also a couple of unknown messages that are always the same 2 messages sent quite frequently. The first unknown message is always the same across all the new Harris systems but the second message is unique to each Harris radio site. Unitrunker will have to be updated to get the dispatcher RIDs from the voice channel messages as they do still contain all of the RID information.
Cheers to you, thanks' for being here to help so many.
maus92
OCMD
The latest release of L3Harris system software has introduces some new opcodes that Unitrunker does not recognize. Our local system(s) were updated earlier this year and are displaying similar behavior to what you are experiencing wrt to dispatcher RIDs showing a zero value.
Unitrunker2
Can someone confirm this is only for ISSI or dispatcher consoles?
maus92
OCMD
That’s actually an interesting question about ISSI, and I never considered that variable. Our local and county systems are technically different systems but share the same WACN and public safety users can roam onto each other’s system as necessary. I’m not sure how they are interconnected.
