Anyone know what keeps the hp 1 from showing any unit id's - this is only happening to 1 system in the same fav. list. Its never happened before this to any of the other systems....
A couple things make sure your display font is not too large. Mine is set at 12. If you have recently updated your scanner its possible when you updated that it reset the UID to its default which is off.
Make sure to check the setting in the radio.
Tim
Have been putting UID'S into the hp1 and hp2 all along and never had them not show for any system as long as I had it turned on and also chose a display mode that shows them.
536/996P2/HP1e/HP2e/996XT/
396XT/PSR800/PRO668/PRO652
MN Armer p25 its worked fine on there for years... I just added a system with a different site and the rid's refuse to work only on that new system.. the font wasnt it either...
