Not working again
dubir
IL
I bought my BCD436HP a year ago, after 5 months it stop working and i ship it to US for repair. The notes was that they replace transistor Q2 and Q3. Now It happen again. I am a month after the warranty time.
I don't live in USA.
Anyone can advise me what to do?
Thanks!!
gary123
I have found that they are not black and white on warranty dates a few weeks has never been an issue in my dealings with them. My suggestion is try emailing them and see if they can issue a return authorization number to speed up the process. If you still have the original repair info make a copy of it and send it with the unit. I would not expect a problem doing it this way.
dubir
IL
Thank you
I will try it..
dubir
IL
Well it is black and white...
Here is uniden replay:
"......Dear Valued Uniden Customer,
Unfortunately, that would have to be sent in for repair and since you are no longer covered under warranty the repair cost for the BCD396XT would be $79.95 +$10 for U.S. or +$15 for Canadian shipping and handling.
Thank you for contacting Uniden!
Mariah
Uniden Tech Support...."
KE4ZNR
Radio Geek
Thanks!!
Mariah
Hmmm...more to the story than we are being told?
KE4ZNR
Radio Geek
I am less than a month after the warranty time
yes but for which radio? You first said you had a 436HP then the email above references a 396XT. 2 entirely different radios.
Sent from my SM-N910V using Tapatalk
UPMan
In Memoriam
Arlington, TX
Note that Q2/Q3 on the BCD436HP are two components that are going to blow if the scanner is subjected to too much RF (i.e. keying up a transceiver in close proximity).
dubir
IL
Thank you for your replay.
Can you please comment to the less than a month warranty issue?
I am using uniden scanners for years and I will be happy for much more understanding.
royldean
Schwenksville, PA
*gulp*
I'm guilty of keying up an HT ham radio within a few feet of my 436... any cut-off to how much wattage is safe within the same room? The most I ever put out was maybe 5 watts.
JoeyC
Senior Member
San Diego, CA
How about starting with answering the question that UPMAN didn't ask, but hinted to.
Are you using this scanner within close range of a transceiver?
KE4ZNR
Radio Geek
Mariah
Once again I point out the obvious in the OPs second post.
Are we dealing with a 436 or a 396XT?
dubir
IL
Hi
My radio is BCD436HP
In Uniden support site you should choose the model but somehow there is no bcd436hp so I chose similar.
So again my radio is BCD436HP
dubir
IL
Dear sir
I am not so good in electronics. But I do like the BCD436HP .
I don't do any unusual things with my scanner
dubir
IL
Dear sir
I don't do any unusual things with my scanner .
dubir
IL
Yes sure, I don't do any unusual things with my scanner. My BCD436HP is in my study room and I have computers and monitors in the room.
I don't have transceivers.
dubir
IL
Hi Sir
Please advise Is that acceptable to get electronic schema to do the repair in my country?
UPMan
In Memoriam
Arlington, TX
We are unable to provide schematics. They are held as proprietary intellectual property.
jonwienke
More Info Coming Soon!
VA
A 5-watt HT isn't going to hurt anything unless the antennas are directly connected (metal-to-metal contact). But you should avoid keying up a mobile radio when the scanner antenna is only a few feet from the mobile antenna.
