What system? I'll play with it. Did you try different settings on the import CC only?
Oh, and are you sure the RRDB version in EZ Scan and the current RadioReference.com are in sync?
One more question once you save you config to a v scanner file how do you get your scanner to copy that file once I move it back to the config it still copies the original files. also is there a way you can rename you v scanner files
Tx
I want to back up a little to make sure this is the file you have.
Did you Extract the file? The Folder should be named CDAT_VS.005
Yes I got the file loaded into my scanner but I go the ez scan software but when I try to down it into the scanner it will only load the config. that I had on the scanner before.
I have done a complete new format of the card then when I try to download it onto the scanner there is nothing in the scanner
I sure it is just a very easy fix but not for me
TX
Figured it out thanks but is there a way to re- name the file?
Thanks for everything I got everything going right
SLScanner
