BCD436HP/BCD536HP: Nothing to scan
JoplinFossil
Joplin, Mo
Would someone be willing to look at the enclosed file and tell me what's the matter. I had this working this working this morning but somehow have messed it up. I have gone back and compared it to some of my working ones but can't see what I've done. I keep thinking it's in my Quick keys.??????
  • (09) Joplin R8 Schools.zip
JoplinFossil
Joplin, Mo
Service types have been enabled, monitoring and download is on. Checked the RadioReference on nothing to scan but can't see anything wrong. I have other programs that will run but I have them turned off trying to figure this out. I feel it's something simple.
I think I found it for some reason under System Quick Key there was a (.) instead of a 0. Have no idea. I'll have to wait till there is some traffic to see if it works but at least it's scanning now.
VK3RX
Thaumaturge
Australia
It sounds like a quick key issue. I see you have "0" assigned to "All".
Press the "0" (zero) key.
ProScan
Software Provider
Ontario, Calif.
You have a Department Quick Key assigned "0" and you have only 1 department. You could set that to None and write to the scanner and see what happens or you could turn on DQK 0 if it's off. Also confirm that the Schools Service type is set in the scanner. That may not matter if you used ProScan to write to scanner and you selected "Turn On Service Types..."
