WS1040: Noticing more garbling/scrambling lately?
Chris321zyx
Anyone else notice more garbled sounds on their trunked digital scanner lately? Do these systems have a setting that makes transmissions come through scrambled so even a digital scanner can’t decode them?
I’ve got a Whistler 1040 that was preprogrammed for me in 2021. Recently, I’ve been hearing way more garbling/“Charlie Brown teacher”–like sounds on trunked channels. I thought it might be outdated frequencies, so I wiped everything and reprogrammed it myself with updated info—but the garbling is still there.
Sometimes the same frequency will be clear, and other times it’s scrambled. If they can scramble transmissions, why not just do it for all of them?
IC-R20
LoBand Nation
Sounds like a simulcast issue. Post a database link to the system you’re listening to.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Welcome to RR.
You probabaly want to go to your location and then first read and then ask about the specific system you are having issues with.
tvengr
Well Known Member
Baltimore County, MD
It would help to know the system you are monitoring. If you used programming software, please attach your file so we can take a look at it. I have ARC500, Win500, and PSREdit500. You will need to zip the file to be able to attach it. Click on Attach files and open the zipped file.
Whiskey3JMC
NI NI NI
Simulcastylvania, TE
Echoing posts above. Please reply back with specific system(s) so we can get eyes on the RRDB to help you troubleshoot
Knowing nothing about frequency(ies) or system specifics I'll venture a guess and say partial encryption (would be denoted as mode De, Te, P25e, DMRe or NXDNe. Small e = partial encryption, uppercase "E" = full encryption
Chris321zyx
Thanks for the replies everyone. I’m going to ask around in the Michigan forums. Go ahead and close the thread here if that’s necessary.
trentbob
W3BUX- Bucks County, PA
Original poster.. I see this is your first thread. Provide us with the state, County and location you are in your county, then we can answer your question.
