Notification: Denver PS district 3 Feed
Scottsbluff, NE 69361
this is to notify RR staff and listeners that Denver PS D3 feed will be down around dates from Fri June 8th - Sat 16th. feed will be back up on 16 or 17 June
we have also fixed our connection issues feed should be stable now. cable internet had a bad coaxial lead in line causing constant disconnection. CATV tech was out and put in a new cable.
thanks
mikev
Northern VA
You may want to put this in the status message for the feed to let the listeners know. You may also want to turn off the "feed is down" emails in the feed settings, so you aren't regularly bugged by the RR servers that the feed isn't online.
